Fxtures removed from cue only cues may not get "Cue Released"
revenant
Postby revenant » 29 May 2023, 12:34
Titan Go V16
Fixtures removed from a cue only cue within a cue list with Cue Release enabled may not be released.
Repro as follows -
  1. Start new show
  2. Patch 4 x Clay Paky Arolla Spot MP 29 DMX
  3. Create a 2 cue list
    • Cue 1 - containing fixtures 1 THRO 4 with Magenta at 100% all other attributes default
    • Cue 2 - containing fixtures 1 THRO 3 with Magenta at 100% all other attributes default
  4. <Exit> <Clear>
  5. <Open/View> {PLAYBACK 1} and set tracking of both cues to [Cue Only]
  6. Set PLAYBACK 1 Options -> Release -> Cue Release to Enabled/On
  7. Set <Clear> option [Clear Selected Fixtures On]
  8. Remove fixture 1 from Cue 2
    1. <Include> {PLAYBACK 1} 2 <Enter>
    2. 1 <Enter> <Clear>
    3. <Record> <Cue> 2 [Replace]
  9. 1 <THRU> 4 [Locate] <Clear> (provides a state to "Release" to)
  10. <Go> twice on {PLAYBACK 1} to assert Cue 2
  11. Observe, magenta on fixture 1 remains at 100% showing fixture is not released even though fixture 1 is no longer present in Cue 2
Note - This issue depends on two conditions
  1. Tracking method is changed to [Cue Only] after being recorded rather than being originally recorded as Cue Only
  2. Fixtures are removed via the [Clear Selected Fixtures On] method
Workaround - After removing fixtures, copy the cue and delete the original
  1. Connect to Cue List
  2. <Copy> <Cue> 2 <Enter> <Enter>
  3. <Delete> <Cue> 2 <Enter> <Enter>
