When i update a palette of one moving head the other one wont do its MID as it should do..
For example, i have 2 moving heads with 2 different palettes, containing pan/tilt and beam attributes.
In the first cue both moving heads have their own palette.
In the second cue moving head no. 2 goes to 0 percent dimmer. (when this light is off it should go to the next palette since MID is set to early)
In the 3th cue the second moving head goes to another palette with dimmer at full
But when i change the first moving head in cue 2 (pan/tilt or beam), then press update and choose the correct palette to update, then press enter. The second moving head (that was in the correct place since MID is on) will jump back to the palette it was before..
I cant figure out how to solve this..
Running V16
Bug? update palette in a cue...
debaggerboot
