Hi! i'm using titan mobile, and i have an issue regard using layouts.
Example:
I create a layout of a group of fixtures, and i recall this layout, but the state of the fixtures (like dimmer, colors etc) dont show up in the layout unless i change the dimensions of the layout by dragging the corners.
This happens anytime i change something on the fixtures, i always have to resize the layout to see the output.
Thx, Claudio
Layout view
Re: Layout view
Is the layout locked? When unlocked the window is in edit mode to allow items to be rearranged, when locked you are able to select and interact with the fixtures. There is also the Show Fixture Mimics option that can be set for the entire layout and on a per fixture basis.
