I was wondering if there was any way to have 2 effects, using any method, go over each other simultaneously.
For example, I hit a key and I get an effect of sunstrip bulbs lighting up from the centre going out, I can hit it again before that effect has finished and the two will overlap with the end of the first carrying on whilst the second starts.
I've been playing around for a while but can't seem to get anything to work. Any tips or even just an answer that it can't be done would be much appreciated.
Fire the same effect simultaneously
Re: Fire the same effect simultaneously
This should be doable with a cuelist. I just tried it with a number of dimmers, and cuelists with different shapes or different pixelmap effects. You can then either set options to 'manual crossfade' and can blend between the effects, or you enter a fadetime.
icke_siegen wrote:This should be doable with a cuelist. I just tried it with a number of dimmers, and cuelists with different shapes or different pixelmap effects. You can then either set options to 'manual crossfade' and can blend between the effects, or you enter a fadetime.
Worked perfectly, cheers
