No group references for Quick Build Key Frame Shapes
revenant
Postby revenant » 25 Jul 2022, 13:03
Arena V15
When creating a Key Frame Shape from a group selection with Key Frame Shape record mode set to [Record Mode Quick Build], no reference between the group and the shape is created.
Repro as follows -
1. Start new show
2. Patch 2 x Dimmers
3. Create a palette with Dimmers at 100%
4. Create a palette with Dimmers at 0%
5. From a <Clear> programmer select the auto generated {2x Dimmers} group
6. [Shapes and Effects][Key Frame Shapes][Create]
7. Set record mode to [Record Mode Quick Build]
8. Tap the palette created in step 3
9. Tap the palette created in step 4
10. [Finish Recording Frames]
11. <Record> to playback handle
12. From the Playback View workspace for the playback created in step 11, tap {Key Frame Shape} from the View Shape column
13. Observe, Group column of Shape View workspace is empty indicating no group reference.
Users browsing this forum: No registered users and 95 guests
