Automatic cue that has a delay, fades in, pause, then fade out
intense-et
Postby intense-et » 20 Jun 2022, 22:29
I need to create a cue (or cue list if need be) that...
with a single button press (tap) will delay (say 2 seconds)
fade in (say 3 seconds)
Hold (say 10 seconds)
Then fade out (say 3 seconds)
Then turn the button that activated it too off
Have searched the manual and looked at the nightclub key profile
However I cannot see how to get it to hold
Appreciate any help
We have just started using avolites titango for installations using the new venue mode for 'non techie' people to operate exclusively
Have a few more questions I will asked seperately
Many Thanks
Re: Automatic cue that has a delay, fades in, pause, then fade out
Postby icke_siegen » 23 Jun 2022, 07:54
this calls for a cuelist:
Cue 1: empty
Cue 2: your desired look @ 100% (e.g. just dimmers at full)
Cue 3: desired look @ 0% (dimmers faded out)
Cue 4: empty (press Clear then record this cue)
And now open this in playback view and set the details:
Cue 1: leave it at default values
Cue 2: Fade In 3s, Link With Previous, Link Offset 2s
Cue 3: Fade In 3s, Link With Previous, Link Offset 10s
Cue 4: link After Previous, Macro 'Release Me'
I programmed this on a button in the Playbacks window. If you do this on a fader handle then you need to push the fader up and then press go in order to make it run, or you set the option 'Fire First Cue' in order to start this with the fader.
