Bug? Merged shapes disappear when <Include> includes tracking shapes
revenant
Postby revenant » 03 Apr 2022, 15:35
Titan Go V15
When including a cue, shapes tracking from prior cues are also included (a behaviour that within itself I don't think is right), merging changes with a cue containing a shape within the cue list can result in the shape disappearing.
Note - This is not an all encompassing fully comprehensive bug report, there are a number of combinations of cue includes, shape states and cue merge options that produce similar but different results, I suspect they are all related and could be considered one bug but not sure. As a number of these bug reports go unacknowledged I am not spending much time detailing the various combinations and outcomes, the repro detailed below is representative of the real world scenario that initially encountered the issue.
Repro as follows -
1. Start new show
2. Patch 4 x dimmers
3. Select dimmers 1 through 4
4. Create Key Frame Shape
5. Add frame with dimmer at 0% and finish recording frames
6. <Record> [Create Cue List] and record contents of programmer as Cue 1
7. <Clear>
8. Select dimmers 1 and 2
9. Create Key Frame Shape
10. Add frame with dimmer at 0% and finish recording frames
11. Set shape spread to 2 (for no other reason than to differentiate between the shapes later)
12. Record contents of programmer as Cue 2 of Cue List 1 ([Append Cue])
13. <Clear> <Exit>
14. Include Cue 2 from Cue List 1
15. Open Effect Editor
16. Observe, the Effect Editor contains the Key Frame Shapes from both Cue 1 and Cue 2
17. Locate the shape with a spread of 2 and set the spread to 4
18. Merge the contents of the programmer with Cue 2 of Cue List 1 (<Record> <Cue List 1> [Cue Number = N] 2 [Update Cue 2] [Merge])
19. <Clear> <Exit>
20. Include Cue 2 from Cue List 1
21. Open Effect Editor
22. Observe, the Effect Editor contains only the Key Frame Shape from Cue 1
Users browsing this forum: No registered users and 90 guests
