Avolites users. Question about clearing.
jiwein
Postby jiwein » 28 Dec 2021, 14:56
I'm new to Titan and have to use one this week. Why is it that when I clear the programmer on this console that it does not release all the values to default?
Is that a behavior that is customizable and how would I change it back? applinked
Also, where do I see what is being recorded to a pallet or cue? It seems I can make a position pallet and it does not work as expected and I assume that is because I have not modified the right attributes.
Re: Avolites users. Question about clearing.
Postby niclights » 28 Dec 2021, 17:19
By default clear will remove all fixtures and attributes from the programmer. You can change this to release via clear options (Hold Clear -> [Options] -> toggle [Freeze Current Values] to [Release To Playback Values]). You can change it back the same way ([Freeze Current Values]). You can find this and more information about clear and it's options in the manual here.
While I wouldn't normally just point the manual I don't think I could explain your question about cues and palettes better. See here and here.
