Bug? Include cue select option can get obscured by Palyback View parameter options
revenant
Postby revenant » 12 Oct 2021, 13:02
Arena V15
When including a cue from a playback, and the playback aligns with a column header from the playback's Playback View workspace that opens, the column header appears to register a touch and the soft menu options changes to the header parameter values leaving no option to select the cue to be included.
Repro as follows -
1. Start new show
2. Open Playbacks workspace in default position (bottom right quadrant of main workspace)
3. Record a cue list in tile 1 of Playback workspace (<Record> [Cue List] (touch empty tile 1 from Playbacks workspace))
4. Tap the cue list playback twice to create a two cue list
5. <Exit> record mode
6. Include the cue list playback (<Include> (Touch the previously created playback))
You should see now that the playback's Playback View workspace has opened with one of the column headers selected (the "Move in Dark" column was selected for me when playback was recorded in tile 1) and the soft menu options are populated with the options related to the header parameter and leaving no way to select a cue to be included.
When selecting the playback for include, two Playback View workspace windows open stacked on top of each other, if the top/prominent one is closed the underlying one becomes the active workspace and the soft menu falls back to cue selection.
Additional note -
I tried to repro and verify this on Titan Go, it presents similarly on that platform. However, only one Playback View workspace opens and closing it does not return the menu options to cue selection, attempting to <Exit> the menu exits the include operation.
