During takeover playback you can change
preset focuses-palettes, you can't select the fixtures all together whith the group function, only one by one. If I am not missing something, then why this is happening??
Pearl question..
paspartu1974
paspartu1974
Hello again,
during playback I am in takeover mode. I use palettes most of the time to change colour, gobos etc. To apply a palette you have to select the fixtures to be applied. I have 16 fixtures. Sometimes I have to press clear in order to do something else, which means that fixtures are de-selected. To select them back again there isn't a "select group" on the AVO screen (like when you are in program..)
cheers,
Alexis
cheers,
Alexis
Ahh. I understand.
To select groups in Run Mode you type the number of the group, followed by 'recall group' softbutton. There is currently no way to view a legend list as in Program mode.
Remember that you can also use 'Quick Palettes' which will recall everything stored in a palette if no fixtures are selected. If you store your palettes carefully you can remove the need to select.
paspartu1974
