I cant delete a playback listed in a timeline. It extended it self all the way to the end of the timeline. after 2 restarts I was able to delete it.
it happens often that a playback extends it self all the way over the timeline. usually it happens when I adjust the time via the wheels.
Cant delete playback in timeline
Re: Cant delete playback in timeline
On a timeline there are triggers for firing, killing and setting the level of a playback among other things. If there is only a trigger to fire a playback and not kill it it will continue to the end of the timeline. It might be that moving the kill trigger to before might be how you would end up with what you describe. That being said this should stop you from deleting any fire or set level triggers you have.
