Hi all,
I'm looking for a way to link BPM masters together. E.g. I'd like BPM Master 1 is assigned to a BPM tap tempo executor, and BPM Master 2 takes its BPM from BPM Master 1, but is set to x2 speed. This way I can have certain playbacks playing at double the speed of the beat I'm tapping along to. Of course I could just set up 2 BPM taps, but would be cool to try this. I've created a 'BPM 2 Tap Tempo' macro, and added it to my BPM 1 Tap, but it doesn't work correctly.
Any ideas here?
Thank you,
Chris.
Linking BPM Masters
Re: Linking BPM Masters
Would using one BPM master and setting the speed multiplier on the playbacks instead give you the result you are looking for?
Yes! That's a great shout. I also created BPM macros (120bpm through to 130bpm) which assign both BPM Master 1 & 2 to the same speed, and master 2 is set to x2 speed. Longer way around but same result. Thanks
