Timeline and zoom
antisthenes
Timeline and zoom
Postby antisthenes » 21 Jan 2021, 19:08
It is a bit tricky to zoom in timeline events. If the working TC hour is 10:00:00:00 for example, pressing the [Fit to View] button shows TC timeline from 0 to 10 hour.
Re: Timeline and zoom
Postby niclights » 21 Jan 2021, 22:06
There are a few ways you can zoom the timeline.
One is by dragging the handles at the end of the viewport representation on the overview bar at the bottom (small bar with three dots arranged in a vertical line).
Another is by enabling Timeline Wheels in the context menu. You can then use the wheels to adjust the zoom.
Or, if you have a keyboard and mouse connected, you can hold down control on the keyboard and use the mouse wheel.
I hope that helps. Apologies if I have misunderstood.
antisthenes
Postby antisthenes » 22 Jan 2021, 15:00
Thanx!
Ctrl+wheel works good. But any thoughts about [Fit to View] button?
I prefer to fit my working hour, not all 24.
Postby niclights » 22 Jan 2021, 15:09
Currently Fit to View zooms the viewport to show everything within the start and end times. Perhaps you could change the start time and duration such that it is for your working hour and then use Fit to View?
antisthenes
Postby antisthenes » 22 Jan 2021, 18:21
niclights wrote:Perhaps you could change the start time and duration
is it implemented?
Postby niclights » 22 Jan 2021, 18:22
Yes. [Edit Times] -> <select timeline playback>.
antisthenes
Postby antisthenes » 23 Jan 2021, 19:34
niclights wrote:Yes. [Edit Times] -> <select timeline playback>.
that is cool!
Ale_Zakko
Postby Ale_Zakko » 08 Sep 2021, 08:26
that's works for me! Many thanks!
subhamsinghh48
Postby subhamsinghh48 » 15 Mar 2022, 15:04
Thanks.. It works:)
stream movies
9apps download
