Bug? Wrong cue can be updated via Cue View workspace
revenant
Postby revenant » 04 Jan 2021, 14:39
Titan Go V14
When attempting to update attribute times within a cue via the View Cue workspace, the wrong cue can be updated.
Repro as follows -
1. Start new show
2. Patch 1 x Dimmer
3. Create a Cue List with Cue 1 Dimmer @100% and Cue 2 Dimmer @0%
4. Exit and clear programmer
5. Open the Playback View workspace for the Cue List
6. Choose "View" for Cue 1
7. From the Cue View workspace context menu choose "Times"
8. Select the dimmer attribute fade cell and enter a 5 second fade value for dimmer
9. From Playback View choose "View" for Cue 2
11. Select the dimmer attribute fade cell and enter a 10 second fade value for dimmer
12. At this point note that fade cell does not show any value
13. From Playback View choose "View" for Cue 1
14. Note that Cue 1 now shows a dimmer fade value of 10 seconds
The issue can be avoided by closing the Cue View workspace before choosing "View" of another cue from the Playback View workspace.
Note, I had to take a couple of runs at double checking the repro as the first time when selecting the fade cell from Cue View, no options for entering/setting values were provided, I could not reliably repro this additional issue.
Re: Bug? Wrong cue can be updated via Cue View workspace
Postby niclights » 04 Jan 2021, 15:31
On behalf of the development team thank you for taking the time to post. I have been able to repeat. It looks like the softkey menu is not refreshing correctly and ends up out of sync. I will add to the database for further investigation (#87503).
Reason: Added reference no.
revenant
Postby revenant » 05 Jan 2021, 14:36
Thank you for confirming and logging the issue, I appreciate it.
