Hi guys. There seems to be some weirdness happening when you swap handle worlds. All the palette tiles are as if they are filtered.
So I have some global colour colour palettes recorded which are for an rgbw fixture and I have an additional fixture group which is RGBL which i want to merge over the top. I set the colour I want then press record, palette, select palette then quick merge.
I then change handle worlds and/or change back to the same handle world. now when I select any fixture or group all the palette tiles are filtered. But the palettes still work and execute correctly. So
If i then subsequently record another palette the filtering goes back to normal. Also it does if you toggle the palette filtering setting in the user settings.
Palette filtering when swapping handle worlds
Avo Machine - v14
Titan Mobile + Fader Wing
Dell Optiplex 7010usff
i7, ssd, 8GB, Intel Hd4000
Capture Machine
2020 Symphony - 2020.0.53
Ai Media Server - 12.1
Capture Machine
Re: Palette filtering when swapping handle worlds
Some more info relating to this.
Show file was created in beta 78 and loaded into beta 90.
The RGBL fixtures were patched using citp after the file was imported to beta 90.
No patching has been done since the new handle world was created.
The new handle world was not a 'blank' world it was based on the default handle world.
I've reloaded the same file numerous times to recreated this condition so I could retrace my steps. And its repeatable even after a reboot.
Avo Machine - v14
Capture Machine
Capture Machine
it's a regressive issue. it does it in v13 too.
there's something really fishy going on with it.
Avo Machine - v14
Capture Machine
Capture Machine
Users browsing this forum: No registered users and 92 guests
