hi, theres some strangeness going on with the clear mode when it's set to 'freeze current values'
when you press clear any intensities you have in the programmer are instantly snapping off and following the master release time
Clear 'freeze current values'
Avo Machine - v14
Titan Mobile + Fader Wing
Dell Optiplex 7010usff
i7, ssd, 8GB, Intel Hd4000
Capture Machine
2020 Symphony - 2020.0.53
Ai Media Server - 12.1
Capture Machine
Re: Clear 'freeze current values'
I'm not sure I understand what you're describing? If you have the "freeze current values" clear mode set clear happens instantly and does not use the release time. The release time is only used if you change the clear mode to "release to playback values". I also couldn't find any difference to v13.0?
Please could you describe the steps you're following, what you're observing, and how that differs from what you are expecting?
Best,
Best,
Pete Bridgman :: Avolites
Perhaps it got changed in some version somewhere then. It always used to be that intensities faded out using the master release time irrespective of what mode its set to but I've just not noticed it because I don't use that clear mode too often.
Haha I'm an old dinosaur thats been using titan since day one
Avo Machine - v14
Capture Machine
Capture Machine
Users browsing this forum: No registered users and 101 guests
