Chases in Theatre Stack
centralchristianchurch
Postby centralchristianchurch » 16 Oct 2006, 21:31
Okay, so I think I have a way to beat the system, by creating a chase with the Martin Mac 500s. The first step is the gobo selection at 0% on the dimmer. The second is at full at one location, the third at another location, while the fourth is at 0% again.
Now, I've unlinked it, so that I can control the chase. Now for the fun part. I have used the autoload feature to add the chase into the song I want, in the Theatre Stack programming mode. How can I control the chase steps once I'm on a cue in Theatre mode? Is it possible?
I use the go button to go between each scenes, so when I press it, the scene changes, not the chase. When I load the chase with the link on, it runs through everything okay.
Is this possible? Thanks!
Signed,
Desperate in Wisconsin
Olie
Site Admin
Postby Olie » 18 Oct 2006, 10:28
I am by no means sure but you may be able to use the flash button of the playback you have autoloaded the chase from. Give it a try, it might work!
