Is it already a way to "backlight" the led on a MidiUsb console ?
T2 + Apc40 mk 2 , i want a way to colorized my boutons
USB midi + T2 , a way to colorized ?
Re: USB midi + T2 , a way to colorized ?
At the moment this is not possible.
This feature is called MIDI feedback. Please log into the avolites website and vote for it here: https://www.avolites.com/ideas/midi-controllers-feeback
I already find out that we can use the "Usb Expert Console" to send Midi on a certain channel ( that lit up my Apc )
If i do it like this way, it works. But is there another way to use this with maccro ??
Thanks for the link, i UpVote !
Exemple : Chanel 0
Command : note On
Data 1 : 4 -> Wich bouton
Data 2 : 4 -> Color
You are exactly on the right track - you can send MIDI by macros. https://www.avolites.de/wiki/macros:example:midinotes gives a good example for this, and the Wiki holds many more useful information and links.
The problem at the moment is that there is no mechanism in Titan to automatically send MIDI when a button is pressed. Additionally, macros can only be set on individual handles or in cuelists, but not in single-cue playbacks. Thus, the only useful way at the moment (as far as I can see) is storing the cue itself somewgere else, and triggering a macrothich does both, sending MIDI, and triggering the cue. That's why I am eagerly waiting for an implementation of MIDI feedback.
Hi. Is there already a solution for midi feedback from the T2 to (in my case) APC 40 MK2. Is this possible with a software update or is it a hardware issue. Is there any work arround. I can imagine more people would like to have this.
There are at least two entries in the ideas section which I'd suggest to endorse:
Users browsing this forum: No registered users and 12 guests
