Titan 2
Titan 14.0 Beta 44
Not a bug, but maybe an improvemnt to make things more clear.
When using Mask FX, in the release notes is stated:
While in this menu the attribute bank buttons will flash. Pressing an attribute bank
button will place a mask shape for the selected attribute group in the programmer
(similar to e.g. 'Block P Shape' in previous versions).
Although with Titan 2 this cannot happen because there are no real LED's in here. Alternative can be to blink the virtual LED's, same like normally happens when you have used this attribute in a cue.
[Improvement] Flashing attribute bank for Mask FX not in T2
renebiemans
Re: Improvement: Flashing attribute bank for Mask FX not in T2
Thanks for your message.
The behaviour you describe is far from unique to the Mask FX Behaviour. If you press [View] followed by most of the banks (other than E and S) you will notice windows opening. It would certainly be an idea to improve these so maybe the border flashes I have noted this on our side.
Peter Budd
Peter Budd
