Store Palette
kimwida
Store Palette
Postby kimwida » 19 Jun 2020, 08:28
Hi, I am trying to store a palette with programmer.
     <step pause="0.01">Selection.Context.Programmer.SelectFixtures("Fixtures", {1,2,3})</step>
     <step pause="0.01">Programmer.Editor.Fixtures.SetControlValueById(240,1,1,true,true)</step>
     <step pause="0.01">Programmer.Editor.Fixtures.SetControlValueById(256,1,0,true,true)</step>
     <step pause="0.01">Programmer.Editor.Fixtures.SetControlValueById(272,1,0,true,true)</step>
     <step pause="0.01">ActionScript.SetProperty("Palette.CurrentPaletteNumber",1)</step>
     <step pause="0.01">ActionScript.SetProperty("Palette.CurrentPaletteHandle", Handles.GetHandle("Colours",0,0))</step>
     <step pause="0.01">Palette.StoreCurrentPalette()</step>
It doesn't work. Only "Palette.StoreCurrentPaletteReplace()" works but I want to make a new palette not to replace old one.
Any help would be appreciated.
Re: Store Palette
Postby icke_siegen » 29 Jun 2020, 14:33
Hi Kim,
the following code works for me
<avolites.macros>
  <macro id="Avolites.Macros.StorePaletteInt8" name="Store Palette Int 8">
    <description>Store Palette Int 8</description>
    <sequence>
     <step pause="0.01">ActionScript.SetProperty("Palette.CurrentPaletteNumber", userNumber:8)</step>
     <step pause="0.01">Palette.StoreMenu.StoreOnButton("Colours", 8)</step>
    </sequence>
  </macro>
</avolites.macros>
Explanation:
throws a casting error (see log collector) because the userNumber needs to be an object, not an Int. Solution: cast it with userNumber:1.
completely breaks the script (don't ask me why)
ActionScript.SetProperty("Palette.CurrentPaletteHandle", handle:"Location=Colours,0,0")
compiles but doesn't work (the palette is recorded but unassigned). I guess this would work only with a currently assigned handle.
Thus, abusing the menu helps:
The only problem is that this always references the current palette page. I don't know if there is a way to record a palette on an arbitrary palette page - there are some functions which simply only work with the current page. Maybe Gregory can shed more light on this.
kimwida
Re: Store Palette
Postby kimwida » 30 Jun 2020, 00:57
It doesn't make color icon in a macro.
So I break it two macros and I got what I want.
Thank you.
Any you can record it any page. I got hint from Avolites-wiki.
<avolites.macros>
  <macro id="MakeColor">
    <name>Make Color</name>
    <sequence>
      <step pause="0.01">Programmer.Editor.Fixtures.SetControlValueById(274,1,0,true,true)</step>
    </sequence>
  </macro>
  <macro id="RecordPalette">
    <name>Record Palette</name>
    <sequence>
      <step pause="0.01">ActionScript.SetProperty("UserMacros.CurrentUserNumber", Handles.Colours.Page.Index)</step>
      <step pause="0.01">Handles.Colours.ChangePage(2)</step>
      <step pause="0.01">ActionScript.SetProperty("Palette.CurrentPaletteNumber",userNumber:8)</step>
      <step pause="0.01">Palette.StoreMenu.StoreOnButton("Colours", 5)</step>
    </sequence>
  </macro>
</avolites.macros>
