How to unlock Shutter Control
rjlkuipers
Postby rjlkuipers » 06 Jan 2020, 18:01
Hello there.
I''d like to set my MH''s to ''Move in Dark" but there is BLOCKED written over the values in the Shutter Control section. How can I unblock these ?
Regards,
Rene
Re: How to unlock Shutter Control
Postby Gregory » 06 Jan 2020, 19:20
The BLOCKED text shown behind attributes in the wheel view indicates that tracked shapes have been blocked on that attribute. This is normally does by pressing the centre section of the wheel display followed by pressing FX in the attribute mask, then in the softkeys there are two options for block and unblock shapes. If you have recorded these to cues it may show this indication when the cue is fired even when the value is not in the programmer. As this only affects tracked shapes it should not prevent you changing the attribute value as normal.
