T2 Dongle
T2 Dongle
I have a new T2 dongle and continue to get the dongle not found message when trying to start the program.. It appears there is no driver downloaded but I cant seem to find the file..I am an experienced Titan user but new to the PC based controllers.. Any help would be appreciated..
Re: T2 Dongle
Which software are you running? You would need to run the Titan Go application which is part of Titan PC Suite v12.0. To diagnose further you can run the USB Expert Console utility to check if the T2 is detected there.
Re: T2 Dongle
That may be the problem I have V 11. I assume the key is in the form of an email as there is nothing in the box and the T2 is advertised as coming with the key.. Ill download V12 and start from there..
Thanks for the quick reply..
Re: T2 Dongle
The T2 is only supported in version 12 onwards. The AvoKey is built into the T2 itself so no additional USB key is required.
