With Titan Simulator versions prior to V12, if I had a T1 plugged in, the simulator app would run in "TitanOne" mode and I could work on show files unencumbered by the DMX spoilers you get when in offline mode.
With V12, the simulator seems to work in offline mode only, I have tried running it with T1, T2 and an editor key but it always comes up in offline mode. As the simulator needs an AvoKey to run I didn't expect offline mode to still exist.
Is there anyway to run V12 simulator without the occasional random DMX data spoilers?
V12 Titan Simulator works in offline mode only?
Re: V12 Titan Simulator works in offline mode only?
This was intentional so that when you run Simulator you are able to simulate more than the one or two lines normally allowed by the T1 or T2. You can override this behaviour by specifying the /online flag on the command line when running the Titan Simulator application, you would then be restricted to one or two lines of output but should no longer get the spoiler.
1. Make a quick access of the Titan Simulator.
2. Right click the quick access and select the properties.
3. Select quick access tab.
4. Put "/online" in target.
5. Ok.
It works!! Thanks!!
5. Ok.
It works!! Thanks!!
- Attachments
- 캡쳐.png (17.86 KiB) Viewed 19953 times
Thank you for the information Gregory, passing the /online flag works for me.
