Hi all,
I would like to know the best and/or simplest way to create a moving head saw tilt where the light is on as it drops and off as it rises. I am thinking along the lines of a two step chase with move in dark on the rise but am not sure if this will work or is the best option?
Thanks in advance for any suggestions.
Move in dark
Re: Move in dark
Provided you are running a reasonably current software version keyframe shapes are the way to go.
Create a kfs with only the dimmers on/off. Then add a layer with the movement. Now offset the layers to each other, change slopes etc. You'll have much fun as soon as you get the hang.
Re: Move in dark
Thank you for the advice - I have just about got to grips with KFS and it was easy to achieve the desired look.
Users browsing this forum: No registered users and 72 guests
