Dear,
Is it possible to use the worlde easycontrol 9 midi controller with titan?
In the software i can adjust several settings on the buttons and faders.. But inside titan nothing seems to happen...
Kind regards,
Jeroen
worlde easycontrol 9 midi console
debaggerboot
Re: worlde easycontrol 9 midi console
Hi Jeroen,
Support for USB MIDI devices on consoles is currently scheduled to be included in the upcoming V12.0 release of Titan. However, USB MIDI will require T2 (or higher) hardware; it will not be available for the TitanOne or T1.
Hope this helps
Best,
Hope this helps
Best,
Pete Bridgman :: Avolites
debaggerboot
Dear,
So the titan mobile wont be supported?
USB MIDI will be available on all hardware except TitanOne and T1, so yes, Titan Mobile will be supported.
Best,
Best,
debaggerboot
perfect! thnx for replying.
LordOrange
If you need to use it before Titan V12.0 comes out, you could use a third party app to map the midi inputs to SaCN outputs and use the sacn as triggers. It's a little convoluted but it works.
- sideshowbond
if you want to use USB Midi on the same laptop as the Titan Mobile I can recommend MidiToWeb
https://www.avolites.de/support-downloads/midi-to-web
This simply translates Midi into WebAPI commands
