Quartz Touch screen slow to respond
djsky
Postby djsky » 20 Jul 2019, 16:49
My Quartz Touch screen response time seems to be slowing down.
When I hit a cue, it takes between half a second and just under a second to actually activate the cue.
Tried calibration etc, and all windows operations and softkeys act immediately.
Is this just a trait of the touch screen? or is there a problem?
Re: Quartz Touch screen slow to respond
Postby niclights » 20 Jul 2019, 16:52
Does this happen if you start a new show? For example with just one dimmer patched and one playback recorded? Similarly, if you flash a memory recorded to one of the playback faders does it respond normally?
djsky
Postby djsky » 20 Jul 2019, 17:26
Yeah, new show one cue works fine.
Existing show, all softkeys and faders work fine. just not the touch screen.
Is it the complexity of my show file? I'm only using one DMX line, even though it's virtually full up.
djsky
Postby djsky » 27 Jul 2019, 09:28
I found the issue!
I had the Capture visualiser open on a secondary screen... closing this window sorted it all.
Users browsing this forum: No registered users and 78 guests
