Hello, I have a question about the 'shape and effect' palette. I have dimmer effects stored in it and the Pan/Tilt effect with all parameters (size, range, speed, etc.) wanting to program something under playback I choose a group of fixtures, position and apply the effect from the above palette then it also adds an effect on the dimmer (which I would like to have in the same Cue as the pan/tilt effect and at this point the whole system falls apart because the motion effect takes speed, size etc with a dimmer effect or vice versa - depending on which effect we will start this game.
What do you have to do to create a cue from palettes and that they do not 'mix'?
P.S. A similar case is when I use the Pan Saw motion effect with certain parameters (from the palette) and then I click on the second effect from the Tilt Saw palette - then the effect of the Circle comes together in this connection.
Shape and effect palete problem
Re: Shape and effect palete problem
What version of Titan are you using here?
Pete Bridgman :: Avolites
Titan v11.3 (11.3.11.5)
edit:
And sometimes i have one more problem:
edit:
Users browsing this forum: Google [Bot] and 28 guests
