TitanOne (simulator) and Capture 2019 connection
jan00147
Postby jan00147 » 06 Jul 2019, 18:54
Hi, i want to connect TitanOne simulator with Capture 2019. I set DMX in Titan and Universes in Capture. then i selected Patch - Active fixtures in Titan. After that i can only select fixtures in Titan (they are highlighted in Capture), but when i want to controll them, it does absolutely nothing, where is the problem? I´m new in Titan and Capture, so it could be something trivial. Thanks for replies.
Re: TitanOne (simulator) and Capture 2019 connection
Postby Gregory » 06 Jul 2019, 23:27
If both Titan and Capture are on the same machine you may want to try using sACN or installing a virtual loopback adapter on your computer. Generally when broadcasting to a network, packets are not sent to the computer they were sent from.
jan00147
Postby jan00147 » 15 Jul 2019, 19:51
Thank you very much!
