Diamond 4 : "Merge" & "Replace"
Kohei
Postby Kohei » 15 Sep 2006, 02:13
When I edit the cue,
1> make the look
2> unfold ( or whatever it's for edit )
3> "RECORD"
4> press "swop" where I want to put this current look
:arrow: 5> this suppose to show "Merge or Replace ?" , but it won't come any message.
in other word, where is the "Merge" & "Replace"?
Olie
Site Admin
Postby Olie » 15 Sep 2006, 14:07
The Diamond 4 does not support Merge or Replace, this feature is only available on the Pearl 2004 software.
You will need to either delete the Cue first and then re-record it to replace or simply record on top of an existing Cue to Merge it.
Kohei
thanks
Postby Kohei » 19 Sep 2006, 01:32
do you think D4 will have this feature?
thanks anyway!
Kohei
Tompa
it does.....
Postby Tompa » 06 Aug 2008, 10:51
you simply do your changes press shift & rec cue (with the little arrow) and place it where you wants to merge it.
I do miss the merge&replace function from the pearl2004 :roll:
djrappa
Postby djrappa » 14 Aug 2008, 10:06
Just go into the record cuelist menu for whatever cuelist you want and then select insert cue and type the number of the cue you want to merge into. You will then be presented with the option of Merge or Replace
Cheers
Clint Dulieu
Lighting Designer
Warner Village Theme Parks
Users browsing this forum: No registered users and 127 guests
