Is this possible (coded macro)
This is a place for people to chare the custom macros they have written.
cramboel
Postby cramboel » 12 Jun 2019, 21:13
Hello, i already ask but without picture last time.
How can i "Touch" my attribute in programmer to get the current color in active "blue", to record this in palette. (current color)
Like that :
Image Image Image
I already have all the step of my macro in coded macro but that section is from the avolites macro ( but is'nt as effiency as i want ) (already have the merge part too)
Thank for your time and your help :D
Site Admin
Re: Touch Attribute
Postby Gregory » 12 Jun 2019, 21:35
If the fixtures are already selected and the correct attribute bank is selected you could do something like this:
Programmer.Editor.Fixtures.SetContextAttributeFromWheelIndex(1)
Programmer.Editor.Fixtures.TouchSelectedControls()
A more reliable way for certain attributes would be to use the attribute ID:
Programmer.Editor.Fixtures.SetContextAttributeFromId(112)
It would be helpful to others to provide more description in the subject in case they have a similar question.
cramboel
Re: Is this possible (coded macro)
Postby cramboel » 19 Jun 2019, 23:16
Thanks Gregory, i'll upload this with details after finish ;)
Both way work but the 2e wont with Rgb fixture or fixture without (color1)
So i'm using the first way, but there is another issue. it NEED to be "color" in the programmer, (bad english so i'll screen this )
I cant find a way to step on color before the line, is this a way ?
I know why but cound solve this, i need a step to do this :////
thank a lot for your time :D
sideshowbond
Postby sideshowbond » 20 Jun 2019, 09:58
You need to set the ContextAttribute right.
I have read out a recorded macro once and use
Menu.InjectInput("OnSelect","AttributeGroup","NoGroup",1)
which works just fine.
1=Intensity, 2=Position, 4=Colour, 8=Gobo, 16=Beam, 32=Effect, 64=Special, 128=Shapes
Users browsing this forum: No registered users and 1 guest
