I'm creating a cue list comprising of three cues, one with a pan shape, one tilt shape, one circle. In between each cue is a another cue containing a Block P shape to stop the previous shape. This works fine but I see in the playback view (view shape column) a small switch appear besides the Tilt and pan shape icon labeled 'Block P Shape'. Switch positions are marked with a T and B.
What is the purpose of this switch and what does the T and B stand for?
Many thanks
Block shapes detail in playback view.
Darrenbeale
- sideshowbond
Re: Block shapes detail in playback view.
T and B mean Track and Block and tell whether a shape from a previous cue is tracked into the next cue(s) or not. So basically in your case you should record your 3 cues (without block cues inbetween) and simply set the switch to B(lock) which prevents your Pan shape tracking into your Tilt shape etc
Darrenbeale
Thats brilliant. Thank you sideshow!
Users browsing this forum: No registered users and 112 guests
