I have a cue running on some pixel bars that has some rainbow color shape going on the sub cells.
I’ve created a white blinder cue that puts intensity to 100pc and all colours to 100pc.
This worked fine, but when I discovered the colours weren’t always full white, because of some of the other running cues, I edited the cue to include the “block all shapes” attribute.
Unfortunately now, it looks like the intensity and colour attributes are gone from this cue.... if I include that cue, there is no blue circle around the I or C attribute, only the FX attribute.
What’s gone wrong?
Block shapes problem
Re: Block shapes problem
I was unable to reproduce this problem, following the following steps:
Are you able to reproduce this problem, and if so are you following significantly different steps? What version are you using?
- Patch {Chauvet, COLORband PiX, 36 DMX} x 1 as Fixture 1
- [1] [Locate] {Shapes & Effects} {Shape Generator} {Create} {Colour} {Rainbow RGB} {Run on Sub Fixtures (Linear)} [Exit]
- [Record] {Record by Fixture} [Playback Swop 1] [Clear]
- Raise playback fader 1. All cells output rainbow chase.
- [1] [@] [@] [Colour] [@A] [@A] [@B] [@B] [@C] [@C] [Record] {Record by Fixture} [Playback Swop 2] [Clear]. Playback 2 has I and C data.
- Raise playback fader 2. All cells continue to output rainbow chase.
- [1] [Enter] {Shapes & Effects} {Shape Generator} {Create} {Colour} {Block All Shapes} {Run on Sub Fixtures (Linear)}
- [Record] [Playback Swop 2] [Playback Swop 2] [Clear]
- Playback 2 has I, C, and FX data, and the cells output plain white.
Pete Bridgman :: Avolites
- sideshowbond
Sounds like you accidently replaced the cue instead of merging into it.
Have you been able to reproduce the problem with the steps provided by Peter?
