Quartz problems!
Stervus
Quartz problems!
Postby Stervus » 16 Apr 2019, 10:34
hi guys!i dont have enough time to read all the topics thats why i created a new one!working with lights for about 20 years!and now got Quartz!its completely new and i have to say that i never saw such a problematic console!it stucks sometimes and loses shows(writing that the files are corrupted!)it already has problems with a couple of faders!its wing is not working properly also!the faders work only like switchers jumping from 0 to 100%!before that i used to work on almost all the consoles in the world including grand MA1,JB lighting Licon,Pilot 2000,Hogs and so on!the console has to be intuitive but here i could not even be able to find any logics!it seems to me that some guys just wrote a program on Windows not understanding the principles of lighting!there are too many submenus!and even a regular thing has to be seeked in the consoles memory!i will contunie and write down all negative and positive points of my view on this strange fixture!
Stervus
Re: Quartz problems!
Postby Stervus » 16 Apr 2019, 18:56
lets go on!2 days ago after starting the console it wrote a warning massage-the showfile is corrupted,unable to load!after loading one of the previous shows i found out that avolites software resetted additional touch monitor settings to disabled!today after some time of programming i found out that its lamp light was not lit!so i called up its menu which was saying-that the lamp is set to full!when i write a show and change the key profiles it needs some time to put them in!it makes me nervous because i am used to work fast and the Quartz does not let me do that!its tooo slow!
Postby icke_siegen » 16 Apr 2019, 20:49
Hi Stervus,
It's not that easy to answer your post as it seems to be a colourful mixture of various things - hardware, software, understanding. Also, if I may say so, a little interpunction, structure, and patience, would help in a number of ways. However I'll try to answer as far as possible - and others may chime in, too. In general I'd recommend to spend an hour or two learning some things, maybe at Avolites in London, maybe at your local distributor. Also, there are many videos available in a number of languages.
Okay, let's start. Sorry for any inconvenience you encounter, no matter the reason. You may believe me that Avolites consoles, as well as all other consoles on the market, are not without problems - but then, they are trusted by a great number of users worldwide for reasons. I am sure your issues can be ironed out.
- maybe this is a rare hardware fault - but could you please give some details, e.g. the software version, and an idea about the show you're running (number of fixtures etc.). 'corrupted show' - can you please give details? What might happen is that it doesn't load the shutdown show at startup time - this happens if you did not shut it down properly, and it shouldn't matter if you saved regularly...
- unfortunately this is known, and can easily be fixed with some spray, within seconds. Your distributor should be able to help you with this. Also, as this is already known and public for some years, it doesn't look like this Quartz is really new.
- again I strongly recommend to be in touch with Avolites or your local distributor. Avolites has a very good training program, and if you'd like to spend a few hours then I am sure you'll find much logic n the way how Titan works.
- have you really worked with that many other consoles? Maybe there are some functions buried deeper than necessary, but in total, I believe the Titan way is very much straight-forward (I may be biased). Give an example of the things you are searching!
- see above. What exactly did the message read? Probably it simply didn't shut down correctly before.
- usually this doesn't happen. But did it properly close last time?
- this is specific to a certain series of Quartz consoles, ans is a hardware issue. Yes, this is unfortunate, but it can be circumvented (e.g. put a lamp-on macro in a startup playback). Hey, no console is perfect.
... key profiles ...
- on this one I am 100% with you - key profiles are a mighty feature but are kinda over-engineered for 96% of everyday tasks. We - Avolites - are striving to get better. Give us a chance and upvote for the request here: https://www.avolites.com/ideas/assign-m ... y-profiles
Stervus - I, and all the Avolites team, take any feedback very seriously. We are always ready to help. Just ask. And again, if you'd spend an hour or two with an experienced Avo programmer then I am sure many questions would immediately be answered.
I don't know where you are based. If you want you can drop me an email at s.beutel@trendco.de. Best regards, Sebastian
Postby icke_siegen » 17 Apr 2019, 07:53
Can you please post the serial number of this console?
Users browsing this forum: No registered users and 67 guests
