Qlab and titan mobile
Michaelg124
Postby Michaelg124 » 16 Mar 2019, 00:53
Het Guys,
I woud like to trigger my titan mobile with qlab, or qlab with my titan.
Is that even possible?
If so, I d like to send a message with a specific que. So for exemple playback 1 que 4. Or if iam triggering qlab just que 4
It is important that i can run thu my ques in any order, syncing qlab with avo. So not just a go message.
Big thanks in advance
Site Admin
Re: Qlab and titan mobile
Postby Gregory » 16 Mar 2019, 01:37
You can use MSC (MIDI Show Control) from QLab to Titan which would allow you fire cues by specifying the cue number. You would need to use the physical MIDI port on the Titan Mobile to do this. MIDI triggers or timecode would also be a possibility however it would be difficult to specify a specific cue. You might also be able to run a script or similar in QLab that could send an HTTP request to Titan's WebAPI.
snorhyvel
Postby snorhyvel » 17 Mar 2019, 18:48
Is there still no support for midi on Titan one?
Is it possible to control titan one from Qlab?
Site Admin
Postby Gregory » 17 Mar 2019, 21:04
No what I said applied to Titan Mobile and not TitanOne.
Michaelg124
Postby Michaelg124 » 19 Mar 2019, 13:33
Okay I have my qlab and avo talking over MIDI.
I cant figure out how to trigger a cue in my list. If Iam in the trigger menu i get the option to select a item to trigger. If i select my qlist its only pressing go, if i select a cue in my list its trying to set legend.
Any ideas?
