Heey,
i'm using titan one with a touchscreen.
when you record a playback and set the key profile to flash all buttons most of the time you have to double tap the button for it to activade.
is there a fix for this so you only have to tap once?
perhaps in windows?
Titan one touchscreen playback press flash function
Jeroen_dereus
Re: Titan one touchscreen playback press flash function
This might depend on the touch screen you are using. Often a continuous press on a screen will be interpreted as a right click and you may only click an item once you stop touching, a double tap might avoid this as it stops it from being treated as a right-click.
There are usually settings to disable right-click, for Windows Touch compatible screens this can be found in the Pen and Touch control panel. Some touch screens also have settings that control if a click will happen immediately when you start touching the screen or only once you stop touching.
Jeroen_dereus
oke thanks for the quick answer.
