Equinox Fusion 50
djsky
Equinox Fusion 50
Postby djsky » 25 Feb 2019, 21:34
Sorry to jump on this post, but you say there is a capture visualiser for the fusion 120’s .... I have fusion 50’s in my setup, but these dont seem to appear in visualiser .... unless I’m missing something ?... how can we get these in capture visualiser? They’re very basic fixtures.
Re: profiles
Postby niclights » 25 Feb 2019, 22:32
Please submit a request via the form on the personality website here and select 'Capture Visualiser (.c2o)' from the Desk Type options. There are two personalities for Equinox 'Fusion 50' fixtures in the library - a 'MKII' and a 'HEX'. To avoid any confusion or delays please enter the full name of the fixture you require Capture support as it currently appears in the library. If you have any problems or further questions please create new topic in the Visualiser section of this forum.
djsky
Re: profiles
Postby djsky » 28 Feb 2019, 17:33
niclights wrote:There are two personalities for Equinox 'Fusion 50' fixtures in the library - a 'MKII' and a 'HEX'.
Cheers, you had me confused for a minute, as it’s neither of those two... and in fact these two are listed under the manufacturer “prolight” but there’s also a manufacturer “Equinox” where there is just one fusion 50 listed.... that’s the one I have.
djsky
Re: profiles
Postby djsky » 03 Mar 2019, 16:42
Wow that was quick... a visualiser file now done... cheers...
One question though... how do I get these fixtures to now appear in my visualiser? I've imported the new personality library, but these fixtures are not appearing in the visualiser.
Re: Equinox Fusion 50
Postby niclights » 03 Mar 2019, 17:04
If you are using a show where the fixture is already patched you may need to update it to the latest version via PATCH, [Edit Fixtures], [Update Personality].
djsky
Postby djsky » 03 Mar 2019, 19:08
Right... done that.... but now my “all fusion 50” Group seems to be messed up...?
Postby niclights » 04 Mar 2019, 17:16
I'm not sure exactly what you mean but I have not been able to find any problem. My test is as follows:
(in Titan v11.1)
- Patch 10x Equinox Fusion 50 in 9 DMX mode using the original version of the personality (this automatically created an [All Fusion 50] and [10x Fusion 50] group in the Groups window)
- Exit to root menu
- Select fixtures 1-5 and quick record a group by double-tapping on an empty handle in the Groups window
- Select fixtures 6-10 and quick record a group by double-tapping on an empty handle in the Groups window
- Clear
- Install latest version of personality
- Restart software (this step should be unnecessary in this example)
- PATCH, [Edit Fixtures], [Update Personality], [Fusion 50], [Ok]
- Select each group in turn
= Each group selects the fixtures as expected.
djsky
Postby djsky » 04 Mar 2019, 17:49
I'm not sure either... they've been patched since v9, so may just be a bug due to the upgrades over time.
I've simply re-recorded the group.
