Im trying to update the visualiser library with a file downloaded yesterday from the Personality Library. The file is called VisualiserLibrary.exe . When I try to run it says Visualiser Software not found. The Visualiser software cannot be installed. Am I right in thinking the visualise library updtes fixtures for capture?
Many thanks in advance. fo
Updating Viisualiser Library
Re: Updating Viisualiser Library
No. The VisualiserLibrary.exe installer is for the 'legacy' Avolites Visualiser which is no longer supported. The Capture library is included in the Titan Fixture Library. You can find a link and instructions on the download page of the personality website here. Direct link here. Please note that not all personalities currently have Capture support. Probably the easiest way to test is to shut down Titan (if it is currently running), download and install the latest library then start Titan, start a new show, open the Capture Visualiser window, patch one of the fixtures and select and locate it. If it has Capture support the outline of the fixture should highlight in the Capture Visualiser window when selected and it should hopefully light in white when located.
Thanks for the clarification. Got it.
Users browsing this forum: No registered users and 61 guests
