Some dimmers are “linked” to other dmx channels?
djsky
Postby djsky » 28 Feb 2019, 18:13
Not sure how, but I have 5 dimmers as fixtures 21-25 in my show, taking up dmx channels 148-152. But in patch view the first two are also showing a lighting bolt behind the user no. and also appear to be taking up channels 153 and 154.
How can I remove this “link” to these other channels?
sideshowbond
Re: Some dimmers are “linked” to other dmx channels?
Postby sideshowbond » 28 Feb 2019, 19:14
what version of Titan are you running. Got 11.1 here and it shows 2 fixtures with the same fixture number when that happens. When I park one of them it disappears
djsky
Postby djsky » 28 Feb 2019, 19:17
V11
I can only see 5 fixtures in my fixtures workspace window, but there are 7 in the list of patched fixtures, the last two have the same fixture and user no.
sideshowbond
Postby sideshowbond » 28 Feb 2019, 19:18
park one of the duplicate fixtures
Postby niclights » 28 Feb 2019, 19:48
Just to add that this occurs if you patch more than one dimmer to the same handle.
djsky
Postby djsky » 28 Feb 2019, 19:54
Well, parked the first one, and then only had 6... 5 good, and one linked... one of the dodgy ones disappeared.
Parked the second, and it removed number 1 good one, and parked the dodgy one in the wrong address.
Un-parked it, and checked my dmx values, and they changed correctly with cues etc, albeit on the wrong address, so re-patched it to the original correct address and it “looks” as though everything is ok now.
Any ideas why this happened?
djsky
Postby djsky » 28 Feb 2019, 20:00
Also, seeing as I’m “spring cleaning” in my patch view, I can see under the “fixture type” column, a fixture that I don’t have patched anywhere... how can I remove this?
Postby niclights » 28 Feb 2019, 20:10
Unforunately you can't at the moment. This is a side-effect of information being retained for things like shared palettes. Hopefully this will be improved in a future version.
sideshowbond
Postby sideshowbond » 28 Feb 2019, 20:21
as this info has already been given away by officials on other mediums: the fixture type filter will only show fixture types present in your showfile in the next version of Titan
djsky
Postby djsky » 28 Feb 2019, 20:26
Nice one, cheers guys! This is probably the most helpful forum I’ve ever experienced. :-)
