Macro Isseu
Myron
Macro Isseu
Postby Myron » 28 Feb 2019, 15:58
I got some Macro's to change dump pallet Color. And Separate dump pallet for Shut things and so on.
So when i have a chase step of 3. With Cue release on.
So you got to have something in the programmer or cue with programmer prior.
Here the thing the color macro's work. But when i do Shutter macro's my dump pallet becomes empty. (basically there is no information in the pallet) No matter what i do with record to store information into the pallet. Pallet mask of intensity wont lit up.
Macro setup.
Record MAcro
Blind Mode
Select Group
Shut open
Record dump pallet
Replace
Blind exit
Macro End
Someone got idea what the heck is going on?
Software running 11.1 Quartz.
Re: Macro Isseu
Postby niclights » 28 Feb 2019, 20:19
I can't reproduce this. Without more details I am having to guess some of the steps but, as far as I can see, firing a macro that places intensity in the programmer and replaces a palette results in an intensity palette regardless of the existing contents or location (for example colour information in the colours window). If you haven't already check that there is no palette record mask set (PALETTE, [Record Palette], [Set Mask]. Intensity should be set to include to record intensity group controls (by default all attribute groups are set to include).
Myron
Re: Macro Isseu
Postby Myron » 23 Mar 2019, 12:06
Somehow i got working, just was not recording the mask of intensity into the palette.
