Winamp and Titan 11
volcker
Winamp and Titan 11
Postby volcker » 30 Jan 2019, 16:57
Hey,
It's me again with another WinAmp question... ;-)
I have created a cuelist and use the timecode from WinAmp to fire the cues, that works ok.
But I would like to know if I have to press play in WinAmp and fire the first cue manually, or if there is a way to get Winamp to fire the first cue when I pressed play.
Re: Winamp and Titan 11
Postby icke_siegen » 30 Jan 2019, 17:11
The first cue behaves like the other cues in the list: if the list is loaded and the timecode for this cue is reached it is fired.
Alternatively you could patch Winamp as fixture and fire the 'Play' in the first cue, so that the first cue starts winamp.
volcker
Postby volcker » 30 Jan 2019, 19:56
icke_siegen wrote:The first cue behaves like the other cues in the list: if the list is loaded and the timecode for this cue is reached it is fired.
Ok I try that. Thank you
Users browsing this forum: No registered users and 81 guests
