StorePaletteMode
sideshowbond
StorePaletteMode
Postby sideshowbond » 23 Jan 2019, 23:26
How would I go on about using
ActionScript.SetProperty(Palette.StorePaletteMode,[value])
in a macro?
When running the API get command I get 2 as a result which would make me assume the modes are 0,1,2 (normal, shared, global) however I struggle to set the property via macro. I get the following in the log viewer
Object of type 'Avolites.Acw.Titan.AcwPaletteMode' cannot be converted to type 'System.String'.
Re: StorePaletteMode
Postby Gregory » 03 Feb 2019, 19:32
For starters you are missing quotes around the property ID. The type of the property is an enumeration so you should either use the Math.ToEnum function to create the value or better still just use ActionScript.SetProperty.Enum.
