Patch 8 fixtures in same channel
orion51
Postby orion51 » 19 Jan 2019, 21:09
Hi everyone.
Is there any way to patch 8 fixtures (Big dipper - LP001) in the same channel (1.1) we use it as a front light so there will be on at the same time, we can assign every fixture itself but now I'm working with visualizer and I can't view the 8 fixtures. For now I trying not to assign every fixture to a different channel.
Re: Patch 8 fixtures in same channel
Postby Gregory » 21 Jan 2019, 11:50
No, the Titan software only supports a single fixture per address as from a DMX point of view you cannot output different values from the same DMX address. This unfortunately means that the default patching in the built in Capture visualiser will also only have a single fixture for each one patched in Titan. It is possible to create more fixtures in Capture but you would require the full Capture application to allow you to edit the project, this could then be imported into the internal Capture window in Titan.
