Touch Screen
Eric. R
Touch Screen
Postby Eric. R » 13 Sep 2018, 12:30
Hello everyone,
How to configure a 2nd touch screen on a Avolites Tiger Touch 2 - Titan 11?
The screen is a IIyama Prolite T2452MTS
Maybe my screen is not compatible?
Should I add a driver?
If you have a solution I am taking
Cordially.
E.Reins
Re: Touch Screen
Postby Gregory » 13 Sep 2018, 16:58
As far as I can see there isn't a custom driver for the screen and it should be supported automatically by Windows. If this is the case plug in the screen (both video and USB connections) and then boot up the console. Then go to Tools > Console Panel > Touch Screen Setup > Windows Touch Settings. Press on the Setup button to assign the correct monitor to the correct touch sensor (you may require a keyboard for this). Most of the time the default calibration of the screen is fine, if not you can select the correct monitor from the drop down list and press the Calibrate button.
Eric. R
Re: Touch Screen
Postby Eric. R » 15 Sep 2018, 18:44
Thx Gregory
