Hello everybody.
I've a quartz and today I discovered that I can control Resolume Arena with it using DMX signal. The Quartz has an ethernet port, so the question is: can I connect the Quartz to the PC using an ethernet cable to send DMX signal or should i buy the device that convert DMX to USB and use a normal DMX output of the quartz?
Thanks.
Quartz and resolume Arena
Re: Quartz and resolume Arena
You can connect the Quartz to the machine running Arena via Cat5. Ensure both machines are on the same IP range too. There is also a video detailing how to set this up on YouTube.
https://www.youtube.com/watch?v=hG0qcR6DpSg
