store look from movement effect titan mobile
jgutworth
Postby jgutworth » 10 Sep 2018, 08:21
Is it possible to store a position pallet from a pan tilt effect? I know it's possible on the MA but I'm having a hard time figuring out how to do it on the TItan.
Thanks!
Re: store look from movement effect titan mobile
Postby Gregory » 10 Sep 2018, 09:25
For normal Shape Generator shapes which you can double tap to Quick Record in the Shapes and Effects workspace window to record the shape to a palette. Alternatively you can press Record then Palette (the button next to the keypad) and select within any palette workspace window ensuring that FX is included in the mask. Unfortunately it is not currently possible to record key frame shapes as palettes.
Postby niclights » 10 Sep 2018, 09:30
I think what Jason might mean is to record the pan/tilt offsets as a 'look' from a paused positional shape. In that case at the moment it is not currently possible.
jgutworth
Postby jgutworth » 10 Sep 2018, 22:51
Correct niclights!
In the Ma you are storing the output instead of what is in the programmer. I guess that is not available on Titan. Maybe one day. I appreciate the help!
