tem alguém que pode ajudar na instalação da tinge touch , eu baixando ja vinhe a licença para instalar
como que teve ser feito
PRECISO DE AJUDA NA INSTALAÇÃO TIGRER TOUCH
antonio elias
antonio elias
Re: PRECISO DE AJUDA NA INSTALAÇÃO TIGRER TOUCH
console tinger touch nao sei faz instalacao tem alguem ai que pode dar uma ajuda
If you have already received your licence, copy the file to a USB memory stick and plug that into your Tiger Touch. On the Tiger Touch press the Import Licence button on screen and select the USB stick, the software will search the USB stick for a valid licence and install it automatically. If the Tiger Touch is currently running with a temporary licence, press Avo+Disk to go into System mode and then select Enter New Licence from the softkeys.
You can also try watching this YouTube video to give you an idea of what to do:
There is also instructions included in the emails that you should have received when submitting your licence or when your licence was issued. Alternatively you could try contacting your local distributor for support.
