Someone tried, does this system work on Titan Mobile + Titan Mobile? Any recommendations?
version 11.0
Multi-user Titan Mobile+Mobile
Re: Multi-user Titan Mobile+Mobile
Yes, multi-user should work between any Avolites console including Titan Mobile providing they are on the same software version. Please ensure that you have setup your network correctly, i.e. each computer on a different IP address in the same subnet/range, and that you have allowed both the user interface (Mobile.exe) and Titan engine (Titan.exe) through any firewall that you have installed. Your computers should also be setup to respond to ping (ICMP) messages, Titan HealthCheck will check for this for the Windows Firewall and offer to fix it if it is not currently allowed. As Windows Firewall has different categories of networks (Private, Domain, Public) you may find that although you have allowed an application to work in one of these categories it is not allowed for your current type of network, Windows does not automatically prompt you again if this is the case so you will need to open up the list of firewall rules to check this.
