Dear all,
I need to do a simple setup where I need to play audio from a source (analog stereo signal) and trigger time code which will control my Titan One dongle. I would like to know how to make the setup in Titan One to receive time code, and which software you can advice to use. I need a software similar to Qlab, but Windows based.
Many thanks in advance.
Viktor.
Titan One receive time code and be controlled by other source
Re: Titan One receive time code and be controlled by other source
Titan can on only receive MIDI (MTC) and SMPTE (LTC) timecode via Avolites hardware which is not present nor available for the TitanOne. The other timecode sources: Internal, Winamp and Clock can be used however are probably not what you want unless you want to use Winamp to play your audio track.
