Titan Mobile Can't Access Fixture Library After v11 Upgrade
Trevor
Postby Trevor » 06 Jul 2018, 16:40
After installing v11 of Titan PC Suite, I cannot access the fixture library. I can access my own user fixtures. Any ideas?
Regards
Trevor
Re: Titan Mobile Can't Access Fixture Library After v11 Upgrade
Postby niclights » 06 Jul 2018, 16:52
If you haven't done so already the first thing I would suggest is to download and install the latest Titan library from the personalities website. If Titan is running you will need to close and relaunch after installing the library.
If that doesn't help then it is possible there is a faulty or otherwise conflicting user personality. Try moving all of the files from My Documents\Titan\Personalities (close/relaunch software after moving). If the factory personalities now appear when patching then try adding one file at a time back to the folder until the problem occurs. This should tell you which file is causing the issue.
Trevor
Postby Trevor » 06 Jul 2018, 18:05
Fantastic, what an incredible service. That was the problem. Thank you.
