Window Properties Macro
sideshowbond
Re: Window Properties Macro
Postby sideshowbond » 21 Jun 2018, 00:13
but you cannot not properly set it that way, you can only cycle between the however many displays you have. And starting point depends on which screen the window has been opened last. Which means I can't pin a window to a specific page. Workspaces can do that so surely there must be a way
Postby Gregory » 21 Jun 2018, 00:18
There is of course internal code that can do this however unfortunately this is not accessible from macros.
sideshowbond
Postby sideshowbond » 21 Jun 2018, 00:22
as a workaround I tried
       <sequence>
      <step pause="0.001"><menuLink id="Windows.Groups" stack="mainWindowStack" behaviour="PushOrRaise" maximised="True" regionId="secondary" /></step>
      <step pause="0.001">UserMacros.RecallMacroById("adb.Macros.screensecondary")</step>
      <step>Windows.SetWindowProperty.X("Windows.Groups", 0)</step>
      <step>Windows.SetWindowProperty.Y("Windows.Groups", 0)</step>
      <step>Windows.SetWindowProperty.Width("Windows.Groups", 1)</step>
      <step>Windows.SetWindowProperty.Height("Windows.Groups", 1)</step>
      <step>ActionScript.SetProperty.Enum("Windows.Groups.ButtonSize", "Fixed")</step>
      <step>ActionScript.SetProperty.Enum("Windows.Groups.TextSize", "Global")</step>
      <step>ActionScript.SetProperty.Integer("Windows.Groups.FixedColumns", 5)</step>
      <step>ActionScript.SetProperty.Integer("Windows.Groups.FixedRows", 5)</step>
      <step>ActionScript.SetProperty.Boolean("Windows.Groups.Pages", true)</step>
      <step>ActionScript.SetProperty.Integer("Windows.Playbacks.CurrentPage", 0)</step>
      <step>Windows.Scrolling.Vertical.Scroll(-100000)</step>
with adb.Macros.screensecondary being
      <step>ActionScript.SetProperty("System.ExternalDisplay.Enabled", false)</step>
      <step>Windows.Stack.CycleActiveWindowRegion("mainWindowStack")</step>
      <step>ActionScript.SetProperty("System.ExternalDisplay.Enabled", true)</step>
hoping I could fix windows to screen 1 when cycled while screen 2 is disabled but that doesn't really work either
